Spoon provides a way to test transformations as follows.
import static spoon.testing.Assert.assertThat;
assertThat('Foo.java').withProcessor(new AProcessor()).isEqualTo('FooTransformed.java');
Assertion Types
There are three types of assertions:
Assert type Description
FileAssert Assertions available on a file.
CtElementAssert Assertions available on a CtElement.
CtPackageAssert Assertions available between two CtPackage.
CtElement assertion example
Let's say that you have a processor which change the name of all fields by the name "j".
class MyProcessor extends AbstractProcessor<CtField<?>> {
    public void process(CtField<?> element) {
To check that the transformation is well done when you apply it on a class, see the following example
final SpoonAPI spoon = new Launcher();
final CtType<Foo> type = spoon.getFactory().Type().get(Foo.class);
assertThat(type.getField("i")).withProcessor(new MyProcessor()).isEqualTo("public int j;");
Note that, method withProcessor takes as parameter either with a processor instance, a processor class name, a class object.
