Figure at the end of this page shows the meta model for Java executable code. There are two main kinds of code elements. First, statements CtStatement (javadoc) are untyped top-level instructions that can be used directly in a block of code. Second, expressions CtExpression (javadoc) are used inside the statements. For instance, a CtLoop (javadoc) (which is a statement) points to CtExpression which expresses its boolean condition.
Some code elements such as invocations and assignments are both statements and expressions (multiple inheritance links). Concretely, this is translated as an interface CtInvocation (javadoc) inheriting from both interfaces CtStatement and CtExpression. The generic type of CtExpression is used to add static type-checking when transforming programs.
Code part of the Spoon Java 8 metamodel
CtArrayRead
(javadoc)
    int[] array = new int[10];
    System.out.println(
    array[0] // <-- array read
CtArrayWrite
(javadoc)
    Object[] array = new Object[10];
    // array write
    array[0] = "new value";
CtAssert
(javadoc)
assert 1+1==2
CtAssignment
(javadoc)
    int x;
    x = 4; // <-- an assignment
CtBinaryOperator
(javadoc)
    // 3+4 is the binary expression
    int x = 3 + 4;
CtBlock
(javadoc)
 { // <-- block start
  System.out.println("foo");
CtBreak
(javadoc)
    for(int i=0; i<10; i++) {
        if (i>3) {
                break; // <-- break statement
CtCase
(javadoc)
int x = 0;
switch(x) {
    case 1: // <-- case statement
CtConditional
(javadoc)
    System.out.println(
       1==0 ? "foo" : "bar" // <-- ternary conditional
CtConstructorCall
(javadoc)
    new Object();
CtContinue
(javadoc)
        if (i>3) {
                continue; // <-- continue statement
CtDo
(javadoc)
    int x = 0;
    do {
        x=x+1;
    } while (x<10);
CtExecutableReferenceExpression
(javadoc)
    java.util.function.Supplier p =
      Object::new;
CtFieldRead
(javadoc)
    class Foo { int field; }
    Foo x = new Foo();
    System.out.println(x.field);
CtFieldWrite
(javadoc)
    Foo x = new Foo();
    x.field = 0;
CtFor
(javadoc)
    // a for statement
CtForEach
(javadoc)
    java.util.List l = new java.util.ArrayList();
    for(Object o : l) { // <-- foreach loop
        System.out.println(o);
CtIf
(javadoc)
    if (1==0) {
    } else {
        System.out.println("bar");
CtInvocation
(javadoc)
    // invocation of method println
    // the target is "System.out"
CtJavaDoc
(javadoc)
 * Description
 * @tag a tag in the javadoc
CtLambda
(javadoc)
    l.stream().map(
      x -> { return x.toString(); } // a lambda
CtLiteral
(javadoc)
    int x = 4; // 4 is a literal
CtLocalVariable
(javadoc)
    // defines a local variable x
    int x = 0;
    // local variable in Java 10
    var x = 0;
CtNewArray
(javadoc)
    // inline creation of array content
    int[] x = new int[] { 0, 1, 42}
CtNewClass
(javadoc)
   // an anonymous class creation
   Runnable r = new Runnable() {
        @Override
        public void run() {
CtOperatorAssignment
(javadoc)
    int x = 0;
    x *= 3; // <-- a CtOperatorAssignment
CtReturn
(javadoc)
        @Override
        public void run() {
          return; // <-- CtReturn statement
CtSuperAccess
(javadoc)
    class Foo { int foo() { return 42;}};
    class Bar extends Foo {
    int foo() {
      return super.foo(); // <-- access to super
CtSwitch
(javadoc)
int x = 0;
switch(x) { // <-- switch statement
    case 1:
CtSwitchExpression
(javadoc)
int i = 0;
int x = switch(i) { // <-- switch expression
    case 1 -> 10;
    case 2 -> 20;
    default -> 30;
CtSynchronized
(javadoc)
   synchronized(l) {
CtThisAccess
(javadoc)
    class Foo {
    int value = 42;
    int foo() {
      return this.value; // <-- access to this
CtThrow
(javadoc)
    throw new RuntimeException("oops")
CtTry
(javadoc)
    try {
    } catch (Exception ignore) {}
CtTryWithResource
(javadoc)
   // br is the resource
   try (java.io.BufferedReader br = new java.io.BufferedReader(new java.io.FileReader("/foo"))) {
    br.readLine();
CtTypeAccess
(javadoc)
    // access to static field
    java.io.PrintStream ps = System.out;
    // call to static method
    Class.forName("Foo")
    // method reference
      Object::new;
    // instanceof test
    boolean x = new Object() instanceof Integer // Integer is represented as an access to type Integer
    // fake field "class"
    Class x = Number.class
CtUnaryOperator
(javadoc)
    int x=3;
    --x; // <-- unary --
CtVariableRead
(javadoc)
    String variable = "";
    System.out.println(
      variable // <-- a variable read
CtVariableWrite
(javadoc)
    variable = "new value"; // variable write
    variable += "";
CtWhile
(javadoc)
    int x = 0;
    while (x!=10) {
        x=x+1;
CtAnnotation
(javadoc)
    // statement annotated by annotation @SuppressWarnings
    @SuppressWarnings("unchecked")
    java.util.List<?> x = new java.util.ArrayList<>()
CtClass
(javadoc)
    // a class definition
    class Foo {
       int x;
