The spoon-smpl submodule provides a prototype implementation of a subset of SmPL (Semantic Patch Language) for a subset of Java. SmPL patches can be thought of as traditional plain text patches with enhanced expressiveness thanks to support for the syntax and semantics of specific programming languages. For example, a Java SmPL patch can be written to specify a generic transformation that reorders of a series of method call arguments without having to worry about matching any specific literal variable names or other literal argument expressions.
Installation
On a Unix-like system, the following set of commands should be sufficient for getting spoon-smpl up and running from scratch.
$ git clone -b smpl https://github.com/INRIA/spoon.git
$ cd spoon/spoon-smpl
$ mvn package
$ ./tools/smplcli.sh
usage:
smplcli ACTION [ARG [ARG ..]]
    ACTIONs:
        patch        apply SmPL patch
                     requires --smpl-file and --java-file
        check        run model checker
        checksub     run model checker on every subformula
        rewrite      rewrite SmPL input
        compile      compile SmPL input
        ctl          compile and print CTL formula
    ARGs:
        --smpl-file FILENAME
        --java-file FILENAME
Alternatively, the command line application can be invoked directly as:
$ java -cp <classpath> spoon.smpl.CommandlineApplication
Basic usage
The basic use case of spoon-smpl involves at minimum two files: one .java source file and one semantic patch. For this tutorial, we will use the following two files:
File 1: example semantic patch (patch.smpl)
type T;
identifier ret;
constant C;
- T ret = C;
... when != ret
- return ret;
+ return C;
This example patch removes local variables only used to return a constant.
File 2: example Java source (Program.java)
public class Program {
    public int fn1() {
        int x = 1;
        return x;
    public int fn2(boolean print) {
        int x = 2;
        if (print) {
            System.out.println("hello from fn2");
        return x;
    public int fn3(boolean print) {
        int x = 3;
        if (print) {
            System.out.println(x);
        return x;
We then apply the semantic patch to the Java source code as follows (output also shown):
$ ./tools/smplcli.sh patch --smpl-file patch.smpl --java-file Program.java
    public int fn1() {
        return 1;
        if (print) {
            java.lang.System.out.println("hello from fn2");
        return 2;
        int x = 3;
        if (print) {
            java.lang.System.out.println(x);
        return x;
Graphical interface
There is a very simple graphical interface available in tools/smplgui.py. This tool requires Python 3 and a suitable python3-pyqt5 package providing Qt5 bindings, in particular the module PyQt5.QtGui. Furthermore, the tool currently assumes it is executing on a Unix-like system from a working directory in which the file ./tools/smplcli.sh is available to run spoon-smpl. As such, it is recommended to start the tool from the spoon-smpl root folder using the command $ ./tools/smplgui.py.
Spoon-smpl graphical interface
The tool provides two panes for editing the semantic patch and some Java source code, respectively. The upper left pane contains the semantic patch, while the upper right pane contains the Java source code. Finally, the tool provides a number of modes for invoking spoon-smpl using the inputs shown in the two panes. To change mode one presses the F6 key followed by the key corresponding to the desired mode, as shown in the image below. To execute the currently selected mode, one presses the F5 key.
Spoon-smpl graphical interface modes
These modes correspond to the ACTION alternatives present in spoon.smpl.CommandLineApplication, with the addition of the gentest mode which generates a test case in a special format for the inputs present in the two upper panes.
Batch processing
Spoon-smpl provides a batch processing mode in which a single semantic patch is applied to a full source tree recursively. This mode is implemented in the form of a Spoon Processor that also features a main method. The following example command is intended to be executed in the spoon-smpl root directory, where a call to mvn package has placed a full suite of .jar files in the ./target sub-directory.
$ java -cp $(for f in target/*.jar; do echo -n $f:; done) spoon.smpl.SmPLProcessor \
       --with-diff-command "bash -c \"diff -U5 -u {a} {b}\""                       \
       --with-smpl-file "path/to/patch.smpl"                                       \
       ## The following options are passed to spoon.Launcher, more may be added
       -i "path/to/target/source"                                                  \
       -o "path/to/write/output"                                                   \
       -p spoon.smpl.SmPLProcessor
The expression -cp $(for f in target/*.jar; do echo -n $f:; done) collects and places on the classpatch all .jar files found in the target sub-directory.
The --with-diff-command option expects a shell-executable command string containing the placeholder expressions {a} and {b}. The placeholders are substituted for the full paths to the pretty-printed input and the pretty-printed output respectively, for each modified file in the source tree. For example, in the event that spoon-smpl during batch processing has modified a file Program.java, the option used in the example command would result in a command akin to the following being executed:
bash -c "diff -U5 -u /tmp/9qKMH/Program.java /tmp/CYd40/Program.java"
Developing
The following code shows the core workflow of spoon-smpl, and is intended to guide developers towards finding the code for the component(s) of interest:
boolean tryApplyPatch(String plainTextSmPLCode, CtExecutable patchTargetExe) {
    // Parse a plain text SmPL patch
    SmPLRule rule = SmPLParser.parse(plainTextSmPLCode);
    // Create the CFG from the executable block
    SmPLMethodCFG cfg = new SmPLMethodCFG(patchTargetExe);
    // Create the CTL model from the CFG
    CFGModel model = new CFGModel(cfg);
    // Create the model checker
    ModelChecker checker = new ModelChecker(model);
    // Run the model checker on the formula that encodes the SmPL patch
    // This uses the visitor pattern
    //   We ask the formula tree to accept the model checker visitor
    rule.getFormula().accept(checker);
    // Fetch the results
    ModelChecker.ResultSet results = checker.getResult();
    // If we get an empty result, there were no matches
    // If we get no witnesses, there were no transformations to apply
    if (results.isEmpty() || results.getAllWitnesses().isEmpty()) {
        // Restore metamodel changes applied by SmPLMethodCFG
        model.getCfg().restoreUnsupportedElements();
        return false;
    // Apply transformations
    Transformer.transform(model, results.getAllWitnesses());
    // Copy any new methods added by the patch
    if (rule.getMethodsAdded().size() > 0) {
        Transformer.copyAddedMethods(model, rule);
    return true;
Scope of implementation as of May 2022
SmPL Metavariables
| Name/Description | Binds | Example | | ———————– | —————————————— | ——————— | | Constant | CtLiteral | @@ constant C; @@ | | Expression | CtExpression | @@ expression E; @@ | | Identifier | CtVariableReference | @@ identifier x; @@ | | Type | CtTypeReference | @@ type T; @@ | | Typed identifier | CtVariableReference with correct type | @@ Integer x; @@ | | Regex1 | Any1 | @@ expression E when matches "regex"; @@ |
constraint (e.g identifier) and adds the additional constraint of the string representation (.toString) of a candidate binding element having to match the given regex.
SmPL Patch syntax
Referenced tests are found at https://github.com/INRIA/spoon/tree/master/spoon-smpl/src/test/resources/endtoend
Description Example Test(s)
Prepend/append to matched context ```java + a(); ctx(); // matched context + b(); ``` AppendToContext, AppendContextBranch, PrependToContext, PrependContextBranch
Delete all matched ```java - a(); ``` TypedIdentifierMetavariables1
Delete around matched context ```java - a(); ctx(); - b(); ``` DeleteStmBeforeBranch, DeleteStmAfterBranch
Enclose matched context in branch ```java + if (cond) { ctx(); + } ``` EncloseInBranch
Delete enclosing branch ```java - if (cond) { ctx(); - } ``` DeleteEnclosingBranch
Dots (computation path wildcard) ```java int v1; ... - v1 = C; + v1 = C + 1; ``` BasicDots, DotsShortestPath
Dots "when any" ```java int v1; ... when any - v1 = C; + v1 = C + 1; ``` DotsWhenAny
Dots "when exists" ```java a(); ... when exists - c(); ``` Exceptions/ExistsDotsPatchingCatchBlock
Dots "when != x" ```java - a(); ... when != b() - c(); ``` DotsWhenNeqExpression/*
"Optional match" dots <... P ...> ```java a(); <... - b(x); + log(x); ...> - c(); ``` DotsWithOptionalMatch/*
Binding metavariables on method header ```java @@ type T; @@ T square(T x) { - log(...); } ``` MatchingMethodHeader/MethodHeaderBinding
Literal matching in method header + params ```java int square(int x) { ``` MatchingMethodHeader/MethodHeaderLiteralMatch
Wildcard matching in method header params ```java T fn(..., Point pt, ...) { ``` MatchingMethodHeader/MethodHeaderDots
Wildcard matching in method arguments ```java - f(...); - f(..., g(..., 1)); ``` MethodCallArgDots/*
Add full method to class ```java + void b() { + System.out.println("Hello, World!"); + } void fn() { a(); + b(); } ``` MethodsAddedToClass/*
Pattern disjunction w/ clause order priority ```java ( - a(); | - b(); | - c(); ) ``` BasicPatternDisjunction
Matchable code
Java elements/constructs you can specify in the semantic patch in order to match against real code, produce new code in the output, or produce transformed code in the output. Not all aspects/features/attributes are necessarily supported.
Description Examples
Literals 5, "Hello"
Type names int
Variable declarations int x;
Assignments int x = 5;
Variable/field references x
Binary operators +, -
Unary operators ++, --
Ternary expressions expr ? then : else
if-statements if (cond) { ... } [else { ... }]
Array types int[]
Constructor invocations new Foo();
Constructor invocations w/ arguments new Foo(1,2,3);
Method invocations println();
Method invocations w/ arguments println("hello world");
Method header w/ parameters void foo(int bar) { ... }
Return statements return x;
“this” access this
Non-matchable code
Specifying any of these in a patch will either lead to unsupported element warnings or exceptions.
Encountering any of these in target code can2 either lead to unsupported element warnings or exceptions.
description examples
Package declarations package spoon.smpl;
Module declarations
Imports import foo;
Comments, Javadoc /* hello */
Annotations @Entity(tableName = "vehicles")
Lambda expressions (int x) -> x + 1;
Classes, interfaces, records, inner variants of
Anonymous inner classes Runnable f = new Runnable() { @override public void run() { ... }};
Instance initializers / anonymous blocks
Array read/write x[4], x[j] = 9
Array constructor new int[42];
Method references Class::method
Assertions assert cond;
Type parameters, intersection types Map<String,Integer> ...
Switch, case, yield
Break, continue
Throw statements throw new Exception();
Try, catch, finally
Try-with-resource try (BufferedReader br = new ...) { ... }
Enums
Loops: while, do, for, foreach
Text blocks """hello"""
Operator-assignments +=, *=
Synchronized statements synchronized(foo) { ... }
step skips over any executables that cannot possibly match the patch, based on the presence of certain strings. Any executables that are not skipped over by the filter can be called candidate executables. Encountering any of the constructs in the list of non-matchable code inside a candidate executable will lead to unsupported element warnings or exceptions.
Matchable but non-producible code
A semantic patch specifying e.g the addition + E for a non-producible E will either lead to unsupported element warnings or exceptions.
Array types int[]
Other helpful resources:
  1. smpl_grammar.txt: covers parts of the currently supported grammar.
  2. Test cases: contains easy-to-read test cases that reveal both supported patch language features and supported Java elements.
  3. PatternBuilder.java: shows the set of matchable Java elements, but can be cumbersome to read.
  4. Substitutor.java: shows the set of transformable/producible Java elements, but can be cumbersome to read.
  1. The Regex metavariable can be applied as an extra constraint on top of any other metavariable ↩ ↩2
  2. There is a prefiltering step when matching a semantic patch against target code. The filter ↩
